Status
Not open for further replies.
1 - 3 of 3 Posts
I was using my 3060, turned it off for about an hour, and went to turn it on again. The remote completely stopped working. I reset my TV/CATV/VCR buttons to the codes and they work now. BUT I can't reprogram the Replay button. I tried to do a reset on it (987/0001) but it doesn't want to accept the 0001 code. I do a 990 to tell me it's current code and it says it is set to 1023. I can't seem to get it to change to anything else.
Your remote permanently dumped the replay device programming. This is known to occur when battery power is interrupted and a button is pressed. You can reprogram the replay device using jp1 cable and hacking software. http://www.hifi-remote.com/ofa/
1 - 3 of 3 Posts
Status
