1 - 4 of 4 Posts
Looking for help. I have 3 (might have 4) comcast boxes, all the same. I have several tvs, some of which are the same make/model. What remote control can I use so that I can address the cable boxes and the like TVs so that my IR commands aren't going to all? In other words, how do I send a signal to change the channel on cable box "A" without changing the channel on boxes "B", "C", and "D"?
I was looking at the Harmony 900 because that has RF, but I don't know if that will solve the problem or not.
Thanks for any input.
Originally Posted by Dropkick Murphy  /t/1418074/remote-to-control-multip...nd-multiple-same-make-model-tvs#post_22190000
The Harmony 900 does not have addressable IR outputs. Try a URC remote w/ RF base station.
It does, but you're only limited to three on the RF base.
1 - 4 of 4 Posts
