remote to control spacer lighting and componets
385 Views 2 Replies 2 Participants Last post by  cofoneIII
i'm a novice and was looking for some help. i'm looking for a universal learning remote to operate my 5 componets and my spacer lighting system. i'm trying to keep the cost under 300. i was looking at the one for all's kameleon and wondering if it will meet my needs or if i need something else. i appreciate all responses. thanks.
Status
Not open for further replies.
1 - 3 of 3 Posts
Im not familar with the All For One line from UE.
Here are some things to consider:
1) Do you want a basic remote that has a preprogrammed IR database that you tell it what device you want to use. Or do you want something more custom that you tell it what you want to do and it sends the appropriate commands (MACROS) and adjust the remotes interface? The latter is especially convienent when incorporating a A/V receiver. Some remotes to look into are MX850 or MX900 from www.universalremotes.com or Harmony remotes which are covered here extensively.
2) Are your components visible? If not, consider a remote with RF capabilities. IR repeaters are also available.
3) Assuming your lights are IR capable.....Do you want to incorporate lighting scenes into your WATCH DVD or other MACROS?
4) What type of components are you using?
See less See more
i'm a novice, so i'm unfamiliar with macros. i'm thinking of hiding my componets behind a cabinet door. i'm controling tv,dvd,dvr cable box, av reciever. and ir spacer lighting. thanks again for all replys
1 - 3 of 3 Posts
Status
