1 - 5 of 5 Posts
I've had this TV for about 4 years now, maybe longer. It suddenly has a series of black horizontal lines running across the screen They're ~1/2" apart in groups about 6" tall, then no lines for 6", then another group, and so on. Also the picture has degraded horribly and is quite pixelated. Bright colors cause a dusting effect across the rest of the picture (although the bright red effect does look pretty cool sometimes).
I tried reinstalling the latest firmware but that didn't help anything.
Would it be worth it to try and get it repaired. My assumption is a main board will need to be replaced. Between parts and labor I can probably get a comparable or even better set for near the same cost.
Any recommendations?
Post some pictures of the screen with various content, including Tv menus/osd.
First attempt to fix would be Y main $300 and/or Y buffer/driver boards $200 each, but more than likely would be the Panel $800 but not available.
The other problem is getting the correct boards. Philips is really bad because one Tv can have 3 or 4 different versions of boards/panels, so buying parts is a crap-shoot.
1 - 5 of 5 Posts
