1 - 3 of 3 Posts
Does anyone have any suggestions or recommendations for a new driver for an ED A5-350? I've heard of them being modified to accept a 15" driver, but if there's an option that could just be dropped in, that would be fantastic. I'd also like to maximize sound quality and reliability for $250 or less if possible.
Banned
 According to what I read, the A5-350 uses a 4ohm, 15" driver that has an Xmax of 28mm.
This is the best I could find in your stated price limit.
The rub, the above linked driver has a Xmax of 20.5mm. The driver I used as a replacement was a 12" driver, which in my opinion was a step down from the above linked driver; an 8ohm driver with an Xmax of 14mm.
A suggestion, check with the guys over in the DIY forum as they have way more experience on these matters than I.
Hope the above helps and good luck hunting.
Discussion Starter · #3 ·
Thanks for the suggestion. I wonder if that one might be looking for more power than the 500W RMS its amp pushes.
Is there any danger to underpowering a speaker?
1 - 3 of 3 Posts
