Status
Not open for further replies.
1 - 2 of 2 Posts
The original remote for my Pioneer DVL919 laserdisc player has died and I'm looking to get a replacement for it but never liked the one that came with the unit. Does anyone know if the remote for the DVL919's older sibling, the DVL91, will work with the DVL919 and if so will the jog shuttle dial on the remote also work (I really miss this feature from my old CLD3060)?
:confused:
Kurt
Yes, it will work! I bought the CU-DV034 remote from Pioneer last year to replace the one included with the 919. It wasn't broken or anything, I just wanted to replace it. It prob wont give you the same jog performance as your old player thou.
1 - 2 of 2 Posts
Status
