Status
Not open for further replies.
1 - 9 of 9 Posts
i have a AE-100, what i need to know does the L200/ L300 use the same lamp. i need a new lamp. thanks for any help, by the way i have logged 4650 hrs. with no problems.
I only have a little over 3200 hours on my AE-100 but I'm still very happy with it and I'm starting to look for a replacement lamp. Does anyone know the cost $$ and how to locate a source or can anyone suggest a vendor??
Thanks for the quick response!!!!!
monomer,
Do you notice any PQ degradation, lamp becomes dimmer, etc?
What about the polarizers? A couple of people reported that they had to replace theirs at around 2000 hours.
1 - 9 of 9 Posts
Status
