1 - 3 of 3 Posts
Replacing a woofer in a 2 way, ceiling mounted.
The speakers are Boston Acoustics 350.
On the front plate it states "4 ohms". What ohms woofer do I need 4 or 8?
There is a crossover for the tweeter and woofer so I don't know if that is considered series or parallel. Thanks.
Not predictable but likely 4ohms. OTOH, the only way to get a match is to get the exact replacement driver from the manufacturer.
Discussion Starter · #3 ·
Thanks for the reply.
The speakers rarely get used and I just wanted to save some bucks with an inexpensive replacement for now.
1 - 3 of 3 Posts
