Viking2000,
Watercooling is a solution for situations where you need extreme cooling without the associated problems of airflow. Instead you have other issues like condensation, tube and waterblock integrity, pump noise, radiator cooling (usually using fans), bacterial blockage, cleaning/draining the system and redundancy. That doesn't even bring into if you start using thermoelectric coolers like peltiers. You're also faced with how to mount the waterblock. I don't know if the lamps in D-ILAs or other projectors have heatsinks or not - if they don't the waterblock is going to be a problem. I've tried most cooling solutions including TECs, water cooling and air based. I would only recommend extreme cooling for situations where there's absolutely no way of getting around it as the result of a failing cooling system can be catastrophic. I'm perfectly willing to risk a $250 CPU+motherboard - no way I'd do the same with a multi-thousand dollar d-ila.
Before going that way there's a number of things you can do with fan based cooling:
- replace the fans with quieter ones that can still output the necessary airflow
- reduce the voltage going to the fan if it's overdimensioned
- if there's a grill in the way remove it - it restricts airflow slightly and will emphasize the noise more
- change the mounting of the fans so that the fan doesn't create vibration noise. I've always been a fan of doublesided tape for this
- hushbox <- of all the most effective. Properly dampened you won't hear the projector at all
/frode
[This message has been edited by Frode (edited 07-17-2001).]
