I bought these somewhere between 1997 and 1999. So they're quite old.
Problem is I don't know what the frequency range is on the two front speakers using the passive subwoofer combined.
I searched around and found the frequency for the speakers are 135Hz to 18kHz. But what is the range on the passive subwoofer.
If I can get that info then I should be able to get some single speakers hopefully small in size that have the same range or better. Reason I want to change is I'm tired of the extra wiring going thru the passive sub. Looks ugly and trying to cut down on the wiring.
I was looking at the Polk audio RM8s which have 95Hz to 24kHz. I can't find any stores in portsmouth NH that have these products I can listen to. So I have to buy and try them.
