Status
Not open for further replies.
1 - 1 of 1 Posts
OK. I have several ReplayTV's. I just added an Adelphia 8300HD box and would like to know - As long as I don't want to pass HD through the Replay TV and record it, can I hook the Adelphia up to the Replay and control it "easily" through the IR Codes?
The main reason for doing this is that I want a networked ReplayTV in my theater so I can pipe programming from the other two into the theater and also record SD from the Adelphia. For HD I'll hook the Adelphia straight into the receiver and switch to the projector via HDMI -> DVI-D
If so, does anyone know what codes to use?
Thanks in advance,
1 - 1 of 1 Posts
Status
