A picture is worth a thousand words.. I took a photo and doctored it up with some measurements. I was hoping to get some advice from all of you gurus.
The TV that is pictured is on its way out. When I built this room, I ran a conduit up to the enter of my room. The 3" conduit comes down the middle of a 2"x8". I also have a power cable up there ran down to my closet so I can plug it into a UPS.. I just have to dig it all out of the drywall we laid over top of it until I was ready to use it..
I was awestruck by the new Panasonic PT-AE7000U.. based on the reviews alone, obviously.. It is very pricey.. I'm certainly up for other suggestions.. but will this beast work well in this room with these dimensions? I will admit, I'm sort of interested in the 3D capabilities.. probably wouldn't use it too much; but I may eventually.. if I ever get ESPN 3D, for instance..
It may sound silly, but I was planning to buy one of the Monoprice Multi-Format projector screens . Thoughts? I can't tell for sure, but it looks like you can manually pull in each of the 4 sides to black out the sections you don't project on.. depending on what format ratio you're watching.. unless that is electric and it automates that.. I doubt it.
I say silly, because if I really spend $3500 on a crazy projector, do I need a better screen than that to really utilize it?
Anyway, I need ideas for a projector mount.. I need to drop it down a foot or so, so it can project UNDER the ceiling fan in front of it.. I'll take ideas for screens and projectors to.
Do I need to widen my front speaker towers? Space them out more? I'm a little worried about doing that..
Thanks everyone!
Here is a shot from when the room was being built.. the left is the back, the right is the front (towards the screen wall).. you can see I have an electrical socket behind the projector area.. All of this is buried under the drywall, so it will be fun to find it.. Luckily I have more pictures to go off of.
Thanks everyone!
/21(Media-Room)/800x600_10-21-2005%2010-53-20%20PM%20Media-Room.jpg)
