Status
Not open for further replies.
1 - 6 of 6 Posts
I'm usually not this lame but I'm having a bit of a headache with this installation. In order to see VCR menus and such on the TV, do I have to hook up S-Video and A/V cables to the TV? Or do menus come thru the Firewire? My Sam T-165 rear panel switch is set to 1080. If I need to use s-video and A/V, do I hook them up to a TV input or an input on the Sam T-165? My main intension is to record and playback OTA HD.
also, if you are recording OTA HD from the Sam T-165 does that mean you can't watch another HD channel while recording?
Thanks for your help.
Newt
The menus DONT come through the 1394 connection. You need a separate video cable. I think it needs to come from the VCR-->TV. I don't believe you can watch a separate channel while recording. I have a separate STB (DST-3000) for viewing programming; I only use my T165 to record.
The Mits also will supply some additional menus and settings if you have HAVi support over firewir such as Bit-Rate. Wait a minute only Mits sets and Promise Module have HAVi support!
Originally posted by Bruce Embry
The Mits Promise Module!
Bruce,
Time to get a life big fella...:rolleyes:
Bruce,
Today is the 15th, do you have your PM yet?
I'm watching carefully to see how the PM is received.
--Rick
What do they say, promises promises... ;)
1 - 6 of 6 Posts
Status
