I know some of the purists will disagree, but I would use it. Air is extremely fluid. I have had a similar situation for over twenty years. I have an Adcom amp in one installation and a receiver in another. Both only have about one inch of clearance at the top. I have never had any thermal issues. In my opinion, the three inch clearance rule is just the manufacturers covering their butts. Just make sure the air is able to flow around the unit and you should be fine.
