Rescue Audio - Part 2 - Once you’ve found something worth taking home
Author - Mark Cerasuolo
In this one Mark talks about in store testing and how to avoid arriving home with a rock instead of a gem.
With thrift-store audio components, testing is not only possible but necessary. Anything marked “as-is” or “minimally tested” (that means they turned it ON) often can’t be returned, and a lot of stuff gets dropped off because it no longer works. Check the store’s policy. Some take returns if you leave the label on the unit, so check it out thoroughly before removing it.
But keep in mind that “no longer works” can be subjective, and may be a simple case of operator error. Many users today simply have no idea what happens when you hit a “tape monitor,” “FM mute,” or “speaker” selector on a receiver or that they even have fuses, so a lot of “defective” gear really isn’t—you just have to check everything to make sure.
Read the complete article at HomeToys.com
