Rescue Audio - Part 3 - Cleaning and touch-up
Final Article in the series
Author - Mark Cerasuolo
I did not say restoration, since that's a whole other subject, although I did touch on fixing up speakers by replacing a bad driver which is pretty straightforward. Electronics restoration generally implies aligning tuners and replacing/upgrading internal components beyond simple lamps and fuses and a good cleaning, which is beyond the scope of this article.
The exception might be a modest rehab through selective replacement of the unit's capacitors, depending on how electronically-handy you are. If you're interested in going that far, I've an engineer friend who recommends DigiKey as a source for any caps you might need.
Read the complete article at HomeToys.com
