resolution for a g90u and hd+ scaler
363 Views 4 Replies 3 Participants Last post by  bomrat
Hi, i purchased a Sony vph-g90u recently, along with a DVDO iscan hd+ with SDI... I want to run around a 106" screen in a light controlled room. Which resolution would you run for the clearist picture from a dvd player?
720p, 1080i, 1080p, and what refresh rate? i am voting 1080p 48hz
thanks.
Status
Not open for further replies.
1 - 5 of 5 Posts
You might want to try both 47.952 for 2-2 pulldown and 71.928 for 3-3 pulldown on NTSC at 1280p.Congratulations on the G-90 !
You might wanna clarify if that 106" is diagonal or width.
the screen size will be a 16x9 52"h x 92"w diagonal 106"...
what would be the best resolution and frequency?
thanks again.
bummer, ended up not getting my pj, it was an ebay scam, luckly i caught it...
well i purchased a g70. lets see how that turnes out.
1 - 5 of 5 Posts
Status
