Yes. Having your XGA FP PJ going at native 1024X768X32bitX60Hz avoids scaling artifacts. Sounds like an ATI driver problem to me. ATI has problems with dual head drivers (they have problems with stability on most of their drivers). I have the cheaper Radeon VE and I have to disable one of the head to have the PJ head working right. Have you tried that yet? I know the new Radeon 7500 and 8500 supports overlays in both heads but I don't think you need both DVD image going on both heads so why not hot key the monitor head off? It may or may not solve your problem but just a thought. Another thought is to remove Hydravision as it's not necessary for the dual heads to work (at least on my Radeon VE). Hydravision seems to make my system more unstable so I disable it on desktop and then uninstalled it on Add/Remove Program in Control Panel (Win98SE). It could be Win2K problems as some time drivers are not as mature on Win2K. Have you tried the latest beta drivers for Win2K that supports Overlays? In Win98SE it's the v7199. It works well for me. In any case, good luck and I hope you solve your problem.
