I'm new to Revel, there is not a massive following in the UK for the HT markert. I've ordered F208's, C208 and S16 surrounds, looking forward to getting them in a few days. I currently have a Anthem MRX-720, will this drive these ok for both multichannel and for two channel music too.
Anyone else running this set-up?
Sit at the apex of an equilateral triangle with speakers toed in 30 degrees, i.e. aimed at your ears. That's how I have mine now and how I've done it since 1974 when I attended the Institute of Audio Research in New York to take the Audio Fundamentals course for recording engineers. In my surround system, the left speakers are aimed at my left ear, right speakers at my right ear for direct sound from each speaker. You can experiment with toe in angles and do what sounds best to you.Just bought F208's. How far do you have them toed in? The manual says to point them directly at you.
Forgive me for not searching >900 pages. Happy to hear recommendations!
For another perspective, I don't toe mine in at all. I didnt like the look of it ( ocd maybe? ) and I'm not the only listener in the room, so i didnt want to focus them on one spot. The great thing about the Revel's is their off-axis response. They still sound great!Just bought F208's. How far do you have them toed in? The manual says to point them directly at you.
I had mine slightly toed in then tried Rex’s suggestion. I also don’t like the look of the speakers toed in so much but the proof is in the sound. While revel is very flexible due to its wide dispersion, if you want the best 2 ch sound quality, Rex’s suggestion (that I’ve avoided off and on for as long as I can remember) is probably the best.Just bought F208's. How far do you have them toed in? The manual says to point them directly at you.
I worked hard to learn audio including getting a degree in Audio Engineering. I learned a lot about stereo recording and playback because that was my profession (recording, mixing, mastering and live sound engineering). My job was primarily recording classical music and I used standard stereo recording techniques, many times just two microphones in an ORTF configuration. For stereo to work as intended, it is essential to follow the guidelines for setting up your playback system. Phantom center imaging is based on psychoacoustics, i.e how our ear/brain processes audio and how we localize sounds. We have two localization cues, time of arrival and amplitude. Stereo recording mic techniques require playback equipment to be set up properly for them to work as intended, i.e. creating a stereo image that accurately recreates the location of objects (instruments) in the soundfield being captured. Stereo is not able to recreate a three dimensional sound field. Immersive surround recording and playback is much more realistic. Think about the sonic experience of hearing an orchestra in a concert hall (something I did on a regular basis). You hear the direct sound of the instruments on stage in front of you and also all of the reflections off the walls and ceiling - you are immersed in the sound from all directions.I had mine slightly toed in then tried Rex’s suggestion. I also don’t like the look of the speakers toed in so much but the proof is in the sound. While revel is very flexible due to its wide dispersion, if you want the best 2 ch sound quality, Rex’s suggestion (that I’ve avoided off and on for as long as I can remember) is probably the best.
Which class D are you getting? Let us know how it works out.Try it and see -- probably work fine. Try to avoid upgradeitus, that insidious, expensive, time-consuming audiophile hobby.
Which reminds me, finally got my M80XC's hung for height speakers hung and wires run to the front, but decided to ship the Crown amps I bought back (need to do that in the next week or two) and pick up a smaller, quieter class D four-channel amp instead so won't be able to hear them for another few weeks.
It was waaay more work than I anticipated, and I had to pull four of my ceiling panels to get the speakers in the right places, so the room is a little more "alive" than before. Also shifted the MLP a little so need to rerun the SDP-75's Optimizer, when I get some free time and interest (MLP moved forward just a little so it is not far off now).
A four-channel NC252-based amp from a grad student putting them together.Which class D are you getting? Let us know how it works out.
DonH50,A four-channel NC252-based amp from a grad student putting them together.
Buckeye Amps: New US based Hypex multichannel amplifier builder, line-up announcement!
UPDATED 1/11/2021 Neutrik speakON connector option now available! Official review by Amir Official teardown by Amir Hey all, Long-time A/V enthusiast with an extensive history on the AVS forums and more recently following this site for all the technical and objective expertise. After months...www.audiosciencereview.com
Wanted something cheap but decent and these look pretty good. I don't need more power than the "little" module for the heights and the amp is pretty small so seems perfect for me. With my work hours I don't have time or energy to build it myself so figured I'd give him a shot. A number of people have them and are happy with them. I should have the amp early February.
The amp is only going to power the heights so I probably won't have much to say about it, sorry. Expecting it will "just work".DonH50,
I can't wait to hear your hands on report from this amp. I just happened upon it the other day on ASR and noticed you mentioned it here.
Thank you! Glad you like my babblings.I have enjoyed reading your contributions on the forum and found them very informative.
There are pictures of my system (old Maggie and new Revel) someplace, probably earlier in this thread. I will post pictures when it is up and running, though the speaker setup is fixed so I could post some pix now. It has changed a bit since last I posted. My equipment list has also been posted but I'm far too lazy to try to find it (and need to get to work). Here is the current media room system IIRC:Would you mind sharing your equipment list and how you are planning on integrating the buckeye amp?
more pics of your performe3Be's would be great also 🙃
Don't you mean 83"?65" LG OLED TV (dreaming of a 75" but put off for a while)
Unless you have goon to the cinema and complained about the screen size, then buy as big as fits your wall(et)Don't you mean 83"?
As I've said before, I honestly was concerned that 77" might be too big, but after living with it for half a year, I'd be content with a 100-110" TV.
Revel C stand is great for C208 but not ideal for C426Be - the bolts don't line up. It's also $300 list price, I would not buy it to cut it down. I'm not sure what it's made of but it has the high end gloss finish. I would have something built, get a piece of furniture or something like this: VCC5 Style | Sound Anchors: Specialty Audio Stands | High-End Home,Professional Studio, and Video | Custom Amplifier Stands, Component Stands, Video Stands, Studio FurnitureDoes anyone know the maximum degrees that the Revel W783 tweeter adjustment allows? I need 51 degrees for my rear surround, ideally. About 45 would do if it really had to.
Also, I need a stand for the C426Be. I read the Revel C stand fits, but it's 11" and I need 8.1". Could I cut down the vertical part? What is it made of?
