After living with a Creative Sound blaster and M-Audio Delta DiO in my HTPC for a year I wanted to try the Revolution 7.1. I got it a few days ago, but it seems that I didn't do my homework on this one.
I'm having problems getting the line in on the Revo to work. I need this for the sound from my TV tuner card, and this was the reason I still had the Creative in my HTPC.
After searching the forum again I found a few post mentioning the problem with line in on the Revo. Has anyone else gotten the line in to work? I find it hard to believe that the Revolution can't do this, when my cheap, 3 year old Creative can do it.
I'm having the same problems as a few others with the signal peaking with the adjustments almost all the way down. In addition to this I have never been able to get sound on any recordings with the Revo. Slipped the old Creative card back in, and everything is just fine (at least when it comes to PVR sound).
Is this a driver issue that is worth waiting for, or should I just give up and find another solution? I'm almost at the point where I give up having a HTPC that will do service as both PVR and DVD/Scaler. I can't seem to find a setup that will function for both. At least not without lots of fumbling with Windows Control Panel and PVR/DVD software when changing functions.
With Regards
Gøran
Oslo/Norway
With Regards
Gøran
Oslo/Norway
