1 - 5 of 5 Posts
I'm installing all new wiring in my house I want to control my lights in the living room via RF remote. what is a good switch with dimmer? and do i need to run cat6 to my light switch location?
You'll need to consider neutrals in every switch box, what control system/remote, and what other switches/dimmers you may eventually want to control.
I suggest you speak with a custom AV company, or put the time in to figure it out. Many lighting DIYers at cocoontech.com forums.
UPB from SimplyAutomated or WebMountain might be a good DIY option. Z-Wave should be considered.
There is not an easy answer.
Most of your DIY lighting automation choices do not use a category cable to each dimmer.
URC (Universal Remote Control) has paired up with Lutron to develop their own RF dimmers that are paired with any of their RF remotes. They have a large selection of remotes and price points. I also suggest searching for a local authorized dealer.
Doug Harbert
Harbert Home Systems
+1
But if you think you might want to control additional lights, look into Lutron Radio RA2. They have IR keypads that will be able to control lights all over your house.
Not necessary. Most remote switches are controlled by a remote controller talking to each other via the house's electrical wires.
Love the Lutron Maestro series. Very attractive modern looking, all software programmable. More expensive than your run-of-the-mill X10s.
1 - 5 of 5 Posts
