My new theater is going to be in the top room of a detached garage that I am building. In order to run the main power to the new building I have to cut through the existing driveway. I also need to put a drain line and my new RG6 satelite wire through there. The RG6 essentially has to take the same route as the power. About 100' in addition to the driveway cut out. Is it alright to run the RG6 in the same trench as the power line? or is there a good chance it will pick up interference? I can probably seperate them about a foot or so under the driveway, but I would really like to run them together to avoid having to dig a whole new parallel trench.
What do you think? I am tempted to try it to make life easier. But if there are issues, I will probably have to run a whole new line.
