Originally Posted by
brenwaterys /forum/post/18199003
You might want to take a look here:
http://www.curtpalme.com/CRTPrimer_17.shtm
For hooking up your 15pin VGA (RGBHV) connection you will want 5 connectors that hook up to the projector (A red, blue, green, H-sync, and V-sync).
Something like this:
The 1271 does not (generally) accept Component into the standard input card. This is why you are getting a green image, you are trying to feed a component signal (Y/Pb/Pr) into the RGBHV input on the projector. Pay very close attention to the type of signal you are using as devices can output both on a 15 pin connection and the standard cable color schemes use red, green, and blue for both standards.
I am using a key digital Hanna scaler
to feed my CRT. One of the connections
is an RGB out and according to the
owner's manual it is stated as RGBHV 15
pin. It is listed under outputs. Also under
the output heading there is component
video out (YPbPr) and right next to
them are H sync and V sync BNC
jacks. I have the capability to choose
from (YPbPr) or RGB from the front
panel. I was wanting to know if I can
come out of the 15 pin RGB using an
adaptor cable that then has the Red,
Blue,Green RCA fittings and plug them
into my Sony 1272 using BNC adaptors
into it's RGB and THEN use H sync & V
sync from the Hanna and get sync from
the Hanna using these syncs to go
into the H V syncs to go into the
1272. Or do I still have to just use
the 15 pin RGBHV coming out of
the Hanna and use the 5 BNC
connection that you stated earlier?
I was trying to avoid buying a long
(15 or 20 ft) adaptor cable. I would
have to get one made. I hope I
explained this clear enough. Thanks,
Makeithappen.
Makwithappen
