deep color is only available on some newer TFT HDTVs, which you should NOT buy because of TFTs bad viewing angles. Instead, a PC IPS panel will give the best picture, in which case RGB range will be full.
Y Pb / Cb Pr / Cr Super-White is only good if your using a CRT HDTV as any decent flat panel will be RGB native and if it isn't its using some screwed up software conversion & should be smashed with a hammer.
am i right?
RGB range is still obscure... I suppose it depends on the display & if its faking 24-bit color...
Is any of this making sense? Your input if you please.
am i right?
