Status
Not open for further replies.
1 - 2 of 2 Posts
For the 75u, I know I need an RGB to 3RCA breakout cable. But my question is this....
Right now my projector will be temporarily wired to my DVD player just to enjoy the thing while I start construction on my theater. Eventually, the DVD player will be moved to the equipment rack and the projector to the ceiling, a distance of 15 to 25'.
Has everyone been buying the cable to length, or is it better to buy just a short length, and then use either a standard RGB cable or component cable to fill out the rest? I could use a short piece now, and then extend it later, or buy the full length now. Would the "joint" where the standard cable connected to the converter cable be susceptible to noise pickup, if I went the short cable route?
Also, everyone seems to be buying these from A2Zcables...Are you buying the premium or cheapie? Direct link or part number appreciated.
1 - 2 of 2 Posts
Status
