1 - 4 of 4 Posts
· Registered
Hi all,
I have a Sony HT-CT150 soundbar that does 3.1 from about 7 years back that has the perfect amount of inputs for my needs, HDMI passthrough, communicates with my TV via ARC, auto-switches audio streams automatically, etc...
I just bought a pair of Polk LSiM 703's and a LSiM 704 center. I cut off the proprietary Sony ends from the speaker cables and wired them up with the new Polks and everything works. I get to use the Sony subwoofer as a bonus.
My question is, what am I missing by not using a dedicated receiver or amp? Am I losing out on sound quality? Volume? Something else?
I'm absolutely trying to go the "cheap route" here before investing in a "super AVR".
· Registered
@fancyaudio you got some pretty nice speakers not to have a receiver drive them to deafening levels. LOL. Not sure what your needs are, but get a nice sub and good receiver and welcome to the rabbit hole!
good budget sub https://www.amazon.com/Bic-Acoustech-PL-200-II-Subwoofer/dp/B074131NKS/ref=sr_1_1?keywords=bic+pl200+ii&qid=1565906149&s=gateway&sr=8-1
7 channel receivers to preview https://www.accessories4less.com/make-a-store/category/avreceiver/home-audio/receivers-amps/home-theater-receivers/1.html?number_channels[]=7
· Registered
You probably dont get the right volume for each speaker.
The sony might have a lot of EQ that suits the soundbar but not speakers.
The crossover is probably set way too high compared to what suits your speakers.
I have yet to see a soundbar «subwoofer» that goes much deeper than capable 6 and a 1/2inch bookshelf speakers, let alone towers, and whats there is usually one note from the port.
The room correction thats in most recievers nowdays can be a big help in many rooms. (And if not its easy to turn off)
You will gain a lot by getting a real reciever and an actual subwoofer even if you go fairly low cost.
That said you do have sound and enjoy it, so no big rush.
· Registered
Discussion Starter · #4 ·
Thank you for the suggestions! That was also my first post - thanks for noticing :). The sub you linked to seems to have rave reviews on Amazon, and according to the dimensions it's not too large. Regarding the receiver, I only have 3.1 and I am 100% sure I will never have more than 5.1 in this room. Is there any benefit to a 7.1 vs. a 5.1 receiver?
I think you're right about the bass - it sounds boomy and there is no way to turn off the soundbar woofer, only turn it down. I still get bass from the bookshelf speakers and it's difficult to tell where it's really coming from. I have to play around with it.
I have lots of research to do!
1 - 4 of 4 Posts
