I have my TV antenna in my attic, coax runs down to a 6-way splitter, and, from there, more coax to 4 rooms in the house. The setup was working fine until recently; I wall mounted all of the TVs, two of which have the coax connector sticking straight out of the back. The coax cable I'm using doesn't bend enough to connect to those sets when they are mounted. To accommodate, I installed right angle connectors on them that I picked up at Lowe's. Since then, the two TV's with the right angle connectors have pretty major issues with several of the TV channels.
The signal loss from the connectors is obviously significant enough to make a difference. My cheap antenna very well could be the root of the issue, but it was sufficient prior to the installation of the connectors. What are my options for correcting the problem, and what would the cost be?
I've attached my TV Fool report. Thanks in advance for any advice!
