1 - 3 of 3 Posts
I've been ripping my blurays to ISO and it seems like I have to put them in their own folder so they can put the metadata in it. Am I missing something? Is there a way to have anydvd HD create a folder for the ISO?
I just got my bluray drive and just started ripping my movies. and this seems like it should be doing this automatically.
Yes, you have to put them each in their own folder (named the same as the ISO). I would suggest using MyMovies' interface to do the ripping for you and it'll create the folder, iso AND add the data to MyMovies. I run Windows Media Center and when I pop in a disk I go to the MM Menu Item and select 'copy disk' and it takes it from there, you can also copy the disk from w/in the MM standalone interface.
1 - 3 of 3 Posts
