Status
Not open for further replies.
1 - 1 of 1 Posts
Hi,
I have an NEC 9PG and a 38" presentation monitor that maxes out at 800x600 60hz and I just ordered HDTV through Rogers cable here in Toronto. They are using the SA3100HD STB that only has component output and both my display devices require RGB. Can I use the 09a62 transcoder with the SA3100HD to feed RGB to my displays? I've heard that the 09a62 only works at 480p, which is weird since Audio Authority says it's not a format convertor so, shouldn't it just transcode the component signal no matter what the source is? The SA3100HD outputs in 1080i format which should have the same timing data as a 540P signal.
Is anybody using the 09a62 with a HDTV source?
Andrew
1 - 1 of 1 Posts
Status
