1 - 4 of 4 Posts
I have got myself in trouble as I search out complexity and perfection. I have a Roku 3 and a Denon AVR 1913 and an older 1080i Panasonic Plasma TH-42PE77U. I also have a Roku 1. Since the Denon has HDMI passthrough switching, I thought this was great: hook up the xbox, blue ray, and the roku to the Denon and output the HDMI signal to the TV. For some reason this setup worked for months. I could get 5.1 sound out of the roku and watch content in an immersive sound experience. Then one day I got the purple screen HDCP error screen and suddenly I couldn't watch any Roku content when plugged into the Denon. I could plug the Roku directly into one of the 2 HDMI ports on the TV and that works fine - just no surround sound.
I complained to Roku, who told me it's not Roku's fault (it's always someone else's fault) and they warned me that a new replacement Roku 3 wouldn't help. I persisted and they sent me a new one, and wouldn't you know, they were right: I still have the same problem.
I am left with a few options:
  1. Give up on surround sound on the roku
  2. Request Denon replace my receiver (still under warranty)
  3. Blame it on the TV and replace that 7 year old item
I know there is considerable chatter about the Roku and HDCP error. I'm interested in opinions on what component is to blame in my setup? I have done various things like switch around the HDMI cables, reverse ends on cables, and put the Roku HDMI cable into a different port on the TV.
thanks!
Jim
IMG_0599.jpg 18k .jpg file
Is your BD player and xbox working without problems? You can always try a HDMI switch from Monoprice. This is how I got around the HDMI dropouts between my Denon AVR and Sony TV.
Discussion Starter · #3 ·
The only item that has any problems is the Roku: both the xbox and the Panasonic BD player have no issues with the switching. Of course I have heard that the Roku 3 is much more likely to have these HDCP issues than the Roku 2. The fact that the Roku 3 does fine directly into the TV make suspicious of the Denon receiver as the possible culprit.
It does sound like it is an issue with the Denon since you have replaced cables and are able to get the Roku 3 to work when connected directly to your HDTV. (I'm assuming you've already tried connecting the Roku 3 to either the BD player or Xbox HDMI input that you know works on the Denon.) One thing to ask although I suspect you have tried this already, are you turning on your receiver before the Panasonic? I ask only because I was having HDCP issues on my Roku 3 when plugged into my AV receiver and discovered that I needed to power on the AV receiver first (in my case, a Marantz) and then power on my HDTV to avoid triggering the Roku 3's HDCP.
1 - 4 of 4 Posts
