Hmmm, I have two 3810R's and haven't had to replace the batteries in almost a year, even if I don't use one of them for over a week. Do not use voice either.
Does your remote have a headphone jack ? See if there is an option to switch the feed off.I have a couple of Roku devices, but the 3810 (with voice command which I never use), appears to eat batteries within a week whether used of not.
I see this posted on Roku forums as a common complaint, but nothing on searches here, Roku usually asks the user to PM them, yet I don't want to join yet another forum.
Right now I use rechargeables, keep the remote in a plastic bag with the cover off.
I think the voice command is always on listening, thus draining the batteries.... any ideas?
Love the device, hate feeding it. It's the 3810, my non voice one the batteries last forever it seems.
My first few sets of batteries lasted several months, then the (new & fresh) batteries would go within a couple weeks even if I wasn't watching it at all. I have been using rechargeables recently which is a no no .Hmmm, I have two 3810R's and haven't had to replace the batteries in almost a year, even if I don't use one of them for over a week. Do not use voice either.
Hmmm I'm not sure, (I keep my remotes wrapped in plastic or in a bag), you can turn the voice off though in which it is disabled.Does your remote have a headphone jack ? See if there is an option to switch the feed off.
Yes this is the streaming stick remote as well.I’ve had this problem with the streaming stick+ remote. I think it’s because I powered the stick with my tvs usb, and the remote constantly searches for a device when one isn’t turned on, so it basically drains the batteries the entire time my tv was off. I remember reading people that hardwired their sticks didn’t have the problem.
The remote is an always connected wi-fi remote. The Roku 3, 4, ultra all also support IR and there are Roku IR remotes. Maybe get one of those.I have a couple of Roku devices, but the 3810 (with voice command which I never use), appears to eat batteries within a week whether used of not.
The remote is looking for a Roku to connect to, not a voice command. Since the Roku is off when the TV is off, the remote is constantly searching.Yes this is the streaming stick remote as well.
That's interesting, I normally leave the set's power tap to "OFF" so not in standby (no standby light), yet is the remote always listening for a voice command?... Then again the Roku I imagine is not powered either way (off in standby, or not powered), so would that matter?
Same theory when I go into Canada, I have to turn my phone off as it will feverishly drain itself looking for a signal that it can't connect to, correct?
Oh, there is no headphone jack on my remote, though there is a TV volume control..
That somewhat make sense, so if I leave my TV in Standby (with the power tap on, & set off) the batteries apparently aren't draining as fast though.The remote is looking for a Roku to connect to, not a voice command. Since the Roku is off when the TV is off, the remote is constantly searching.
Or that's my understanding of why they drain so fast.
So my remote is Wi-Fi as well? but how is it turning on & TV, has to be using IR.The remote is an always connected wi-fi remote. The Roku 3, 4, ultra all also support IR and there are Roku IR remotes. Maybe get one of those.
CEC most likely, depending on your setup.So my remote is Wi-Fi as well? but how is it turning on & TV, has to be using IR.
