Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I have a room with the following dimensions
Length 22' 7
Width 12' 7
Height 13'
The only dimension I can really change is the height. Any advice would be helpful (acoustics? aesthetics?)
And any advice on screen size.
· Registered
I cant tell what you are asking, except for the screen size. My thoughts are go as BIG as possible while maintaining the the seating distance 1.5x (1.5 x screen size) away from the screen.
1 - 2 of 2 Posts
Status
