First off, thanks to all -- have been lurking for a very long time, now am finally starting my "real" HT project. Have run into an audio/room design problem though. My basement room measures about 15 feet wide by 18 long. Due to structural requirements I must retain a room pillar within the room (7 inches square, floor to ceiling) about 5 feet from the front screen; the pillar is offset from the side wall by 3 1/2 feet. (I cannot "header" this thing away due to an already low 7 1/3 foot ceiling height). Also -- I have in the opposite rear corner of the room a large soffit area about 30x30 inches which will extend from the floor to at least 4 feet off the floor (like a big box stuck there in the corner).
Planning right now on 3-4 seats on a sofa on a riser in the rear row and 2-3 seats in the front row, with a likely setback for the front primary seats of about 10 1/2 feet from the screen. Planning on a ceiling mounted projector of some kind, with all audio/video equipment racked out of the room itself.
My questions are these:
1. Should I shift the front screen (planned for about a 100 inch diagonal) away from the pillar (L/R) -- or otherwise can I make the pillar acoustically invisible by adjusting its shape from square to something else?
2. Should L/R speaker placement avoid a line-of-sight block to the primary seats?
3. For the rear soffit -- would it be better to finish it with an area at the top to mount one of the rear surrounds, or just finish the soffit to the ceiling?
Many thanks for the ideas.
