I built two sliding, rotating pads for the equipment in my den. Since the equipment is in a built-in cabinet over a 57" RPTV, it makes for much easier wiring configuration/ reconfiguration.
I am about to start on some modifications in my HT. I intend to do the same thing with the equipment sliding out of a corner cabinet at an angle and then allowing rotation for rear access.
Good luck with your design!
