1 - 2 of 2 Posts
I just got a used Rotel 965 receiver and am having some trouble with it.
I am not getting any sound from it. It seems like the receiver is in 'Video1rec' mode and probably that is why it is cutting off the sound.
Can anyone help me figure out how to get the sound back from the receiver?
Does someone know how to reset the receiver to factory settings?
I have a similar problem with my old Rotel. I'm simply going to use it as a home theater unit for sound only. I have an optical digital cable from the TV to the Rotel (Video 4) and I can't ge sound. I noticed in th set up mode, "Input Select" had the source set to Analog. The Default setting is "Auto" which allows either analog or digital input. However, the remote will not budge the setting from Analog. I too, am looking for a way to reset the system to factory settings.
Help needed soon!!!...
1 - 2 of 2 Posts
