Hi,
I am going to buy the following:
Channel Master 3671 antenna
Channel Master 7777 pre-amp
Channel Master 9521A Rotor
I live about 60-70 miles from most of the transmitting towers and was going to mount my antenna on my rooftop using a mast with chimney mount straps. My chimney is 5 feet above rooftop. Will the rotor go at the very bottom and rotate entire mast or do you place the rotor as close to the top as you can. Also, how high is too high for the mast if just suported by 4 chimney straps especially if rotor is at top of mast? Is 15 feet too much to support the weight? I plan on using a mast that is in 5 foot sections that says heavy duty. I wanted to go to 20 feet but feel that might be to high. I plan on using 4 of the Channel Master chimney straps and they look like they will hold mast sturdy and in place.
Thanks for any help,
Mike
Mike
