In my question to build an over-engineered HDTV reception system, I want to install an antenna rotor. I probably don't need it since 90% of the stations are located at the same location, Sutro tower. But I want to be able to get KICU and KNTV (for when it becomes an NBC affliate). I also just think a rotor is retro-cool! http://www.avsforum.com/ubb/smile.gif
Can I put a 10 foor mast into the rotor or will that torque the rotor too much when the wind blows? (i.e. should I only use a 5 foot mast in the rotor?) The antenna is a Channel Master 3018.
Any other general rotor advice?
