Status
Not open for further replies.
1 - 3 of 3 Posts
Does anyone else experience low brightness levels on their RP91?
I had to adjust the user settings in the RP91's menu to correct the brightness levels. Progressive mode looks fine but interlaced mode has the brightness problems.
Banned
You might try changing the "set up" controls from "darker" to "lighter" in the main set up menu.
That would effectively make your darks brighter because the output is being changed from 0 IRE to 7.5 IRE NTSC set up.
1 - 3 of 3 Posts
Status
