1 - 6 of 6 Posts
Hey all, i am trying to turn on a A/V Reciever with a RS232 command using the VB6 comm32. To turn it on it says to use:
Code:
Code:
Command code | Parameter code | CR  | Code set example
 PW           | ON             | | PWON
And this is my VB6 code i am currently using that doesnt seem to work...
Code:
Code:
MSComm.CommPort = 2
   MSComm.RThreshold = 1
   MSComm.Settings = "9600,N,8,1"
   MSComm.InputLen = 0
   MSComm.PortOpen = True
   MSComm.Output = "PWON" & Chr$(13)
   MSComm.Output = "PWON" & vbCrLf
   MSComm.Output = "PWON" & vbNewLine
   MSComm.Output = "ZMON" & Chr$(13)
   MSComm.Output = "ZMON" & vbCrLf
   MSComm.Output = "ZMON" & vbNewLine
   MSComm.PortOpen = False
End If
The reciever never turns on. What could i be doing incorrectly? I checked to make sure the com port was 2 and it is.
The PDF of the rs232 commands can be found here for the Marantz SR7005: http://www.filefactory.com/file/b45c...ceiver_All.pdf
If anyone has experience with MSComm32 then please help me out
David
You may want to confirm by using Hyperterminal or similar first.
Also, I'm not sure why you are sending 3 different types of carriage return or line feed. I suppose the carriage return command/character is needed so did you try choosing a single line and using it? Maybe you just figured you'd try different techniques and if one of them turned it on, great.
I didn't check the rest of it in detail but it looks fine.
Note that Hyperterminal (or similar) might not work. It does not work with my Denon because apparently the inter-character timeout in the Denon is very short and I can't type that fast. I don't know about other receivers. So sending the whole string in a burst may be necessary.
1 - 6 of 6 Posts
