Status
Not open for further replies.
1 - 4 of 4 Posts
RTV2000 is not telling my Motorola (Comcast) cable box to change channel in order to record the correct show.... RTV goes ahead and records at the requested time, but it records whatever channel is left on the C Box.... Got Serial cable running from C Box to RTV
Any ideas ???
For my ReplayTV 3060 remote, the Motorola cable box code is 276. My IR blaster works almost all the time but sometimes either the ReplayTV or the cable box gets confused and I get the wrong channel and wrong show at the right time. But then it works great for months so hang in there and be patient with the IR blaster technology. Good luck. :)
Rick
1 - 4 of 4 Posts
Status
