I'm trying to upgrade my 5060 (a Costco version that actually has an 80G Maxtor drive inside) to a 200G Maxtor drive.
I installed both drives on my IDE 2 bus with the original replay 80G drive as master and the new drive as slave. (I moved the jumper on the original drive from CS to master).
I ran the RTVPatch version 2.4 from Win XP SP1 and the program says my original drive is 80G but it says that it's "NOT a ReplayTV Disk".
Here is the log file:
0) MAXTOR 6L060J3 - (60 GB) - NOT a ReplayTV Disk
1) Maxtor 6Y160P0 - (163 GB) - May be PC Disk
2) Maxtor 4R080L0 - (81 GB) - NOT a ReplayTV Disk
3) Maxtor 6Y200P0 - (203 GB) - NOT a ReplayTV Disk
Source: Select a drive from the list and click 'Set'
Target: Select a drive from the list and click 'Set'
RTVPatch version 2.4, built on Jan 19 2003, 12:54:57
\\\\.\\PhysicalDrive0 (MAXTOR 6L060J3) : Detected size = 117266688 sectors
\\\\.\\PhysicalDrive1 (Maxtor 6Y160P0) : Used WinXP drive size detection
\\\\.\\PhysicalDrive1 (Maxtor 6Y160P0) : Detected size = 320173056 sectors
\\\\.\\PhysicalDrive2 (Maxtor 4R080L0) : Detected size = 160086528 sectors
\\\\.\\PhysicalDrive3 (Maxtor 6Y200P0) : Used WinXP drive size detection
\\\\.\\PhysicalDrive3 (Maxtor 6Y200P0) : Detected size = 398297088 sectors
I moved the jumper back to CS on the drive but I get the same result.
I'm afraid to proceed since the drive isn't recognized properly, I haven't put it back in the replay yet to see if it still works.
Any help is greatly appreciated.
PS I did a search of the forum for RTVPatch and went through 11 of the 20 pages returned, but I need a break LOL
