Status
Not open for further replies.
1 - 4 of 4 Posts
Has any one played around with Ruby's horizontal lens shift option?
I will likely need to use this just a tad - probably to shift the picture about an inch or so.
I'm wondering if that may have any effect on convergence (already shaky to being with) and brightness.
Perhaps the MC will be less visible with your lens shift change. Why assume the worst?
Discussion Starter · #3 ·
No worries. Not assuming the worse. Just want to avoid any surprises. In the event that using the horizontal lens shift causes greater misconvergence than there already is, I'd need to know that up front.
I would be very interested in the outcome, since I will definitely need to push the horizontal shift fully to the right - that is, when I finally decide to buy a Ruby...
1 - 4 of 4 Posts
Status
