1 - 2 of 2 Posts
Discussion Starter #1
i am setting up a runco dtv991 with remote rc6011. the rgb gain as well as other functions do not function. i entered passcode 3151 but still do not have these functions. i do not see anything about this in the manuals.
R, G, B GAIN ADJUSTMENT will only be available when the PJ is connected to a NEC ISS switcher, and the PJ set to SW1 level in the CONNECT CONDITION menu (with the switcher in non-standalone mode / DIP switch S8601: 8 open).
Can you select RASTER CENTERING, FOCUS BAL. and REF.WHITE BALANCE when you are in the REF. ADJUST menu after you entered the passcode?
Kai
1 - 2 of 2 Posts
