If you are seeing light.. is it white or have color.. I am thinking your color wheel is not starting. Typically the color wheel or power supply are the items that fail and ends these tanks.. If the fan run, I think you are good, never noticed when that fan starts. Since you have power it is not the power supply. A lamp "can" cause this and still give that low level light. My money is on the color wheel being dead. Remover the color wheel and see if it is very hard to turn. The ribbon cable pull out of the connector. The plastic connector is part of the board and does not come off. I have seen ribbon cables bent and strapped too tight which damaged the traces. Be very careful with the Color wheel it is extremely fragile.
Good luck and no I do not have a source for color wheels that work correctly.. ebay stuff is junk and not worth messing with.
