Hello all,
I'm getting close to finishing my basement and HT area. I've decided to drywall my ceiling area instead of using a drop ceiling application, my wife thought it looked nicer
Anyway, my AV equipment will be over on one of the side walls in a built in area. I am trying to figure out how to run my Componant/DVI cables to my Sanyo Z2 front projector. I decided not to route them above the ceiling, in the event technology changes or if I ever need to change to a differant cable. So I'm trying to come up with a solution to route them along the ceiling over the the projector in some type of enclosed channel system that I can access in the future. I thought about making something out of wood and staining it to match the trim in the room. I've also read up on the Raceways that Cableorganizer offers in a white poly material, which probably would look ok next to a white ceiling, and they appear to be latching so you can access the cables if needed.
Just looking for any ideas you all may have...thanks Randy
