Hi guys,
This is the fourth place that I have lived in with my projector/screen. I have the PJ and screen up, but I'm at a loss for how to effectively run the power and HDMI to the projector. I am renting this place, so I have to stick to my landlord's wishes.
The projector is about 12' from the front wall and 6' from the sides of the room. I intend to run the cable from the projector, straight to the right wall, down the wall, and then to the front of the room where the receiver is.
The room is finished, and in the basement. There is no way to access the inside of the ceiling, so running cables through the walls or in the ceiling is out.
The ceiling is done with a stipple surface. I cannot attach cables or channels directly to the ceiling, because I will damage the stipple and when the cables are removed, it will leave an obvious flat spot and look terrible.
My only idea so far is to get a cable channel, put the HDMI and power cables in it, and then screw the cable channel into the ceiling with very small screws but not screw it flush to the ceiling. I'd leave a small gap between the top of the channel and the ceiling. The majority of the ceiling would be untouched this way. When I move out, I can just fill the screw holes and it should not be noticeable.
Any better suggestions?
