Got a great deal on a Philips 60" DLP rear-projection TV. I have it set up in my living room, now I want to get my computer hooked up to it for gaming, DVD, and web surfing (like anyone else here).
Link to TV: 60PL9200D/37
http://www.samsclub.com/shopping/nav...=5&item=338607
http://www.consumer.philips.com/cons...CSHQFHKFSESI5P
Panel resolution : 1280x720 (720p)
Computer is an AMD Athlon XP, 1gig OCZ memory, and my video card is an ATI Radeon X1600 Pro. I am using the DVI output with a DVI-HDMI cable to input into the back of the TV.
It works, but it's not the quality I was expecting. All the text is semi-blurry, uneven, doesn't look great quality. The whole screen doesn't extend to the edges of the TV either.
My roommate hooked my cable up between his PC via DVI-HDMI to his 32" LCD, and it looked crystal clear, no blurriness or anything (His is 720p also). I understand mine is bigger, but it still should be better than it is.
I don't know if 720p just isn't enough to get the clarity I'm looking for? Or, if my settings are incorrect, and I need to change a few things around?
Or, is a projection TV just the wrong type of TV to use for this?
I've searched a bit on here and saw something about 1:1 pixel mapping, so I went to wiki and researched more on it. I vaguely understand what it means now, but not sure if I need it, or should have it already? Is it for a x768 display or for a x720 display? I assume I should have 1:1 PM, and I saw the example too of what it's supposed to look like, mine definitely doesn't look like that.
Thanks for any help you can give!
