I am wondering what you guys would recommend for the crossover between my two subwoofers.
So here's the deal... I recently added an extra, smaller subwoofer to my home theater setup, the idea is to fill in the higher bass frequencies so the large one can concentrate on the nice low extension rumbles. I don't know the square footage of the room, but it is a bit challenging because it is a living room that has a vaulted ceiling and is open to the kitchen. The large sub by itself sounds great, but I can tell it's being challenged (I've heard it "pop" a few times... it was being driven hard but the volume level didn't sound unreasonable. I'm sure more power would help but I'm not quite ready to open things up.)
Just for reference, the main speakers are Infinity Primus models, the reported low-end response is as follows: Center 80Hz, Mains 50Hz, Front Height and Surrounds 60Hz. I have the crossover for each speaker in my Onkyo receiver set for 10Hz higher than those numbers.
The larger sub is a 15" JBL PSW D115, with 350 watts of power, and extension down to 25Hz (some report 20Hz, which would make sense considering the size, but I'm sure it depends on the room). The smaller sub is a 12" Pinnacle PS Sub 150, with 150 watts of power (200 peak) and extension down to 30Hz.
My thought is to use an inline high-pass 50Hz crossover for the smaller sub, but maybe then I'm not giving the large sub enough to do? I don't want to rely too heavily on the lesser of the two subs... but I want that nice, clean extension as much as possible.
What do you guys think?
