I recently purchased my first home, it's a 1950's home and I just found out the exterior walls are double brick construction with plaster directly on the brick wall. I only found this out recently after having planned and purchased a few items to get ready for the installation. I was planning to run all the wiring for power, speakers (5.1) and A/V in the wall. This is now not possible since there is no gap between the plaster and the brick. I am somewhat at a loss at how I am going to accomplish my goal of having a clean look with little to no wiring showing.
The TV is being mounted above a stone fireplace/mantel directly onto the wall. This doesn't pose much of a problem but I don't have any power source for the TV or motorized wall mount above the mantel. I was initially planning to run a 5.1 setup but now with the walls being as they are I don't know how possible this will be. I believe the interior walls are single brick construction but have to confirm. I am thinking of drilling a hole through to the exterior and running conduit to a point behind the TV and making another hole there and running the wiring that way. The only issue with this is the power situation.
Has anyone ran into this situation before and what solution did you have?
Should I abandon my hopes for 5.1 and consider selling my receiver in favor of one of these soundbars? Or should I just look at doing a 3.1 setup with the current receiver I purchased already.
Hope someone can help!
