Russound PC Power Tool
7652 Views 6 Replies 7 Participants Last post by  LittleRockStudios
Does Anyone here have a copy they can send me of the Russound PC Power Tool Disc? It would really be great.... Thanks in advance.
1 - 7 of 7 Posts
Your one Cruel Puppy there Paul
See less See more
I cannot believe this software is not free! I am an installer whose partner has this on his laptop but he cannot find his installation CD. I need to get a copy on my laptop. I am willing to prove my partner's legit copy if you know a way I can do it. I am willing to pay someone for their time. PM me.
I doubt Russound is willing to send another copy but I will try that route as well. I can also try to drag and drop the the software folder onto my laptop (probably will not work, but is worth a try).
If your company(partner) has purchased PC PowerTools and has properly registered it, you'll be able to download it.
Once properly registered it can be downloaded from the Russound Document Center. Who ever registered it will need to sign into the Document Center with their username/password before they have access to the downloads.
If your partner never properly registered the software, the serial number is what's required for registration and this would have been located on the original disks (that are lost). I don't think the software itself shows the serial number anywhere where you can view it on your partner's PC. You might try a call to Russound tech to see if they can assist???
Cheers,
Paul
See less See more
Now available for free download from russound
This is now available for download for no charge on the the russound web site
look for
pc_powertool_st_1_0_0_32.zip
here
www russound com slash document-center/20-legacy-products/70-source-equipment/72-firmware-software/[/url]
pcpt_v2_0_1_8.zip
here
www dot russound dot com slash document-center/20-legacy-products/50-cav-cam-systems/56-firmware-software-updates[/url]
See less See more
look for
here
pcpt_v2_0_1_8.zip
here
Do you still need the serial cable for the update?
1 - 7 of 7 Posts
